no hazzard lights or headlights
bmxunderground
217
4
Dec 11, 2007
Bowling Green, Kentucky
I got into my car started it as usual turned on the headlight column switch. All of my interior lights work. My parking lights work. Blinkers work. My headlights however; do not come on. Also, the high beam indicator light (blue) is on. Whether I click the lever on or off the light stays on as long as the dial is up.
I tested the harness at the headlights and they are not receiving any voltage at any point. Replaced headlight relay in the engine bay junction box with known good relay and still nothing.
I attempted to find the black box behind the radio like on my 95 but it isnt there. Only a 3 prong relay.
I've checked every fuse and examined all wires I could see without pulling major parts off. If there is someone here that could give me a tip or two please do.
I've been having to bum rides the past few days after the sun goes down because I can't track down the problem. If anyone has tips on a direct method of wiring the lights please let me know as well. I need to be able to at least run "rigged" at night until the problem can be traced.
Bad column lighting switch.
In emergency you could remove headlight relay and jumper the top 2 slots with a wire large enough to handle 20 amps (12 gauge). This will keep the headlights on as long as the wire is there until removed, but at least you have lights. This assumes a bad column lighting switch is the problem.
traced the wires found a break near the engine bay fuse box. Repaired it and the headlights work. Everything works as it should now with the exception of the hazard lights, they still do not operate. Any suggestions before I get back into it tuesday?
