no fuel pressure after apr install when car shuts off?
mach1one
232
Nov 30, 2003
A B., Alabama
My friend and I installed an aeromotive afpr last night. We noticed that last night my fuel pressure went down pretty quickly after it shut off, and hovered around 10. Today as soon as I cut the car off, it goes to 0. We set base pressure at 36.
I was under the impression that the fuel pressure should stay up for awhile after shutting off. It takes a bit longer to crank since it's got to build pressure back up. I'm still running the stock rewired fuel pump, 255 is on its way. Any ideas?
I thought it was normal. Mine sits at zero when the car is turned off. If this is an issue can someone please fill in.
After awhile it should settle to 0, but I didn't think it would happen right away. My friend's settles down much slower. Takes quite a few more clicks than it should to crank it, my starter might be dragging and I'm thinking its the fuel pressure.
Yea mine drops down alomst instanly. I have a 190 pump in there, maybe I should rewire it amd check my fuel filter. I know it atleast takes me 2 tries to crank my car over almost everytime. So I take it that I have an issue. :mad:
Your "aftermarket" regulators do not function like the stock regulator does. It is normal for them to "let go" of the fuel immediately after you turn the engine off.
I had this problem with my fuel pressure dropping to zero after immediately shutting car off. Problem solved by replacing the o ring on my walbro w/high pressure fuel line
Thanks, the car is acting more normal now but I'll be putting on a 255 later this week. :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
