No first and second gear.
92DSM89
67
4
Apr 15, 2009
Boston, Massachusetts
I only have 3rd,4th,5th,and reverse. In other words what should be first and second, is third and fourth. I installed newer cables that only have one adjuster compared to the ones i took at which had adjusters on both cables. I also put in new aluminum shifter linkage bushings and base bushings. The clutch has been bled as well.
Are you sure you didn't replace 1990 cables with 1991-1994 cables? There is s difference in length and they are not interchangeable.
Tim Zimmer via Evo Phone
well its a 92 but it had the 90 cables in it i believe im not really sure whats going on there. but i did fix the problem the bracket on the transmission was reversed, flipped it around and im good to go. thanks
  • Wanted 6 bolt NT water pipe
    • chrisman287
