no fire prob/crazy need help
e96eclipse
51
Jan 3, 2010
vanceboro, North Carolina
i have a 97eclipse gst i recently broke the balance shaft belt and it jumped timing and bent only 8 of the valves on the intake side and thru all the rocker arms on the intake side. so after stripping it all down replacing all the valves redoing the head puting everything back together and replacing the crank sensor cause it somehow got damaged in the process. i get everything back together and now i have no fire going to plugs... ive changed the crank sensor,cam sensor, ignition control module checked all fuses and i still have nothing and my pockets are getting thin... i need help cause now i dont know what to do. thanks
Double Check that the CPS isn't backwards =) Also, are your injectors pulsing?
Did you remember to plug in the little power transistor thing on the backside of the motor? It's attached to the intake. It's easily missed. ALOT!
i feel like a complete idiot LOL the cps sensor was backwards! LOL but got it running and drove a week and balance shaft belt broke again!! fml its fraid all up idk why it keeps happening. so now im thinking of a delete kit and getting rid of it. does anyone kno if thats a smart idea? ive heard good things and heard bad. and how hard is it to install??
