Kyogie12
- 306
- 0
- Feb 14, 2010
Boulder,
Colorado
Been searching around and couldn't find specific help for my issue.
This is on a 97 GSX that just finished a rebuild. Went to connect the battery last night to start it up and break it in and my roommate connected the ground terminal for the battery to the positive post. That blew the 100amp Alt fuse in the hood. I had the MFI (motor) fuse pulled to prime for oil anyway. However there is no CEL on acc key turn. Checked the ecu and nothing looks burnt (95 eprom with ecm link). However i'm not getting power from pin 12.
This lead me to believe this blew the MFI relay out. I've found info on the 95 relays and how to test. But this being a 97 it has the two mfi and fp relays next to each other. Just wondering if anyone had specific info on how to test that mfi relay and see if I can restore power to the ECU.
Thanks. Other thoughts on what else might have blown out would be appreciated too.
