1G no crank issue
Silencio
Feb 26, 2011
buffalo, New York
hey
i got 1g talon tsi awd has a 5 speed swap from a galant it stalled on me the other night under normal driving hasnt restarted. it is getting spark but seems like its not getting fuel pulled the plug they were dry as a bone. i didnt hear the pump kick on at all. getting power to the relay and the pump. could the pump be shot or something much much worse?
Your title says no crank issue, but you say it's not starting in your post. Is it not starting or not cranking?
If you have power and ground to the pump it should work.
its cranking over fine i re did a spark test with a tester no go there i pulled the computer to to crack it open an make sure everything is intact the way it should be. had power and ground on the pump i had no fuel pushing to the engine
A bad MPI relay will cause no fuel or spark. If you don't have either I would bet on that being you problem.
zander i check the relay with a battery still clicking but i will try that. i did pull the computer out just in case it was the curse. board checks out okay. thank the dsm gods i dont wanna have to swap it out. just for reference the car has 66k miles.
0 pressure in the fuel system at all. it just randomly stalled. i dontknow if im looking in the right spot for the fuel pump relay. someone said under the center console near the computer. so is it the 3 prong relay that i see or is it a little black box looking thing mounted right to the floor in front of the computer?? my car has been sitting almost the entire month to bs problems like this its really getting on my nerves.
