stratt134
- 132
- 1
- Apr 9, 2006
Houston,
Texas
When I turn the "ignition" on, the check engine light comes on (as the test, so the bulb works)
But when I throw CEL codes, like P0170, P0446, idle code, speed sensor code, etc etc - the check engine light NEVER comes on!!
AND none of the emissions test will SAVE... like I -permanently- have the P0446 Evep code come up, once I clear it, it comes right back, no check engine light, 1000 miles later not ONE diagnostic test has been saved to the ECU (you know those 5-6 test that must be *completed* before you can pass emissions)
Anyone have any ideas?? Is my ECU retarded or something??
, i put my dsmlink in so i have just had it in my eclipse box of stuff.
