no check engine light
yepes281
971
Mar 22, 2009
H-Town, Texas
So for as long as ive had my car i have NEVER seen my check engine light come on, not even at start up. Whats wrong with it??? :confused:
well i mean i have no cat so i know im throwing a code. it just doesnt light up, but i dont know why.
Have you scanned the car to know there is a code? Do any of the lights on the dash illuminate when you insert the key into the ignition? Do you have both the front and rear o2 sensor installed?
When i try to scan it it wont connect. And the only ones that come on when i insert the key are the seat belt and open door light. The previous owner installed some reverse gauges and ive noticed hes not the belt with electrical. When i turn on my brights my gauges turn off. So would it be just a burned out bulb or fuse? If so how do i check this?
You might want to check the bulb an replace it if it's burned or missing.
Some people will take this light bulb off when they sell their car if the check engine light was on, and since you say that the light doesn't turn on when you turn the key at start up than maybe yours is either burned or missing...
It's really easy to check. Take the gauge bezel off and take the gauge cluster off by removing the four screws holding it in place and see if the bulb is missing on the back and replace, if the bulb is there than test by putting it on another bulb's spot that you know lights up when you turn the key, if it doesn't than replace.. obvious really..:cool:
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
