Nitrous Controls and Methanol
ypnas777
301
Feb 24, 2003
North Andover, Massachusetts
I have my methanol injection system wired up exactly like the diagram below. I was wondering exactly what modifications I need to make in order to be able to control the system using the dsmlink nitrous controls via the fps solenoid.
I read those threads but I don't know which is the "ground side of the relay" as described in the previous thread. The diagram above clearly shows that none of the relay wires go directly to a ground. I just want to know exactly which wires I need to move around in my setup to make it work. Thanks
Black goes to ground. Use the ground before the boost switch if you want it inline, if not use 85
