NGK 6ES 1 step colder
dls93tsi
441
Nov 21, 2003
Schuylkill Haven, Pennsylvania
I put new spark plugs in my car today, and I got the NGK 6ES, but one step colder....when I put them in, I also had reset the ecu, b/c of some problems I was having. I took the car out for a drive after idling a good 5-10 min. and it ran fine, except when I gave it gas, it would buck and miss like crazy.
After a few minits(sp) of driving, it got better and better. I did 2 logged runs, the first i was knocking at about 6 and my feul trims were at 120 high and 160 low. the second run, my knock was down at 0-1 and my feul trims were 100 across the board.
I am wondering if the bucking was the plugs, do they need higher cylinder temps to run right or was it my ecu relearning the parameters?
No, they are 6's, just a step colder, not a full phase, to the 7. it runs great now, its just until the engine warmed up fully...thats why i though maybe it was the colder plugs..maybe it was just the ecu reset..
.028 on all 4. I know better than to put in plugs w/out gapping them myself
The 6s are stock heat range and the 7s are 1 heat range colder the ES means the same thing the #s are what you look at. Keep the 6s in unless you are running bigger than a b16g. The plugs just wont get hot enough to clean the carbon off them and foul up causing problems. Make sure the conection from the plug termanal to the inside of the coil is making good contact. The boot slides on the wire very easy making it look like the wire is on the coil ok.
The spark plugs would not cause this "bucking" unless they were completely defective. Trying swapping to other plugs and see if there is any difference. Sounds like to me you have a boost leak somewhere.
I have the bpr7's and every stage 1 mod just about and a 14b turbo not a 16g and my car runs just fine on the "colder" plugs.
From what you've said, I'd guess the difference you have in plugs is that you've gotten away from the projected tip. Not a good move for street use.
NGK has no "half-steps" in heat range. 6's be 6's, etc.
What is the diff. w/ a protected tip and unprotected...besides the chance of pregnancy...
Now that's funny bro!! :p
But Really what is the diff? I never heard of a protected tip...
Also Let me ask this... I have a t-25 witha Greddy 24R and hard pipes with Type S and a big intake.. With this setup should I stay with Stock plugs? Thanks in Advance :dsm:
opps, sorry defiant..i didnt read carefully enough..my bad OMG
