Newb rim question
Tha Fella Dylan
242
Jan 9, 2012
Algonac, Michigan
I know I don't have the offset but i was wondering about this rim/lug pattern:
17x7" bolt pattern 5x114.3 and 5x100
Will that fit on my 2g eclipse no problem? And if I go an inch bigger will an alignment be recommended?
Thanks and sorry for the stupid question. Thought id ask before i bought them. Wasn't sure about them as a set.
That's two different bolt patterns! Only the 5 x 114.3 will fit.
Offset is depending on how far (sideways) you want your wheels to stick out, and should change with how wide the rim is. To be able to know how much the rim will stick out or if will even fit you need Rim width, and offset.
Wait. Lol. Let me ask a stupid question again. The part that says "5x100" means there is two different rim sizes? I'm assuming the 5x100 ones wont fit? He said he was selling them as a set of four.
Sometimes wheels are drilled with 10 holes to be a "universal" 5 lug. If that's the case the two bolt patterns would be 5x100 AND 5x114.3, unlike the wheel Brian posted which has one set of holes for a 5 lug application and one set for a 4 lug PCD.
Edit -Like this one:
