new turbo hitting coolant pipe
bigbrdf250
59
Dec 9, 2011
SugarLand, Texas
so i ran into a lil problem tonite while installing my sbr g-60 turbo. was about to bolt it up to the head and realized the housing is hitting the coolant pipe.
im sure someone has came across that when installing the bigger turbos??
can i beat it with a hammer??
what options do i have??
i really wanna get this thing goind this weekedn
thanks, i have searched but no luck!!!
You will have to dent the waterpipe a tad bit with a hammer. Just be careful not to abuse the waterpipe and make a hole. Good luck
You will have to dent the water pipe to squeeze the housing in. Use the hammer but be careful wrap a towel around the end of the hammer and dent it in. People have ran into this problem including myself being one of them running my AGP 60-1 turbo.
do u guys recommend me taking it off the car and beating it or can i do it in place without any damage? thanks for the replies
Easiest to do it out of the car. While it's still mounted though you want to mark the spot where you want the dent to be. Then just remove it and have at it.
easiest to dent off car but have seen many do it on the car. Just wrap it up when you hit it or use a blunt object nothing like a punch to knock a hole in it something thicker
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
  • For sale AEM Series 2 Total Control Plug And Play Stand Alone ECU For Sale
    I am selling my AEM Series 2 plug and play, fully programable, stand alone ECU. I had bought...
    • LSM
  • For sale 2g 2g passenger side PW switch
    Passengers side PW switch. Good condition. Message 702-741-6987
  • For sale 2GB Factory Owners Manual For Sale
    I am selling the factory owners manual warranty info booklet, and maintenance booklet, all in...
    • LSM
