NEW TO DSM"S motor swap help~!
kidcobra
Aug 3, 2004
pelican rapids, Minnesota
Hi im new to dsm cars im a mustang fanatic, but i got my dsm's for a good deal and figured i would give them a try. ok i have a 92 eclipse gs-t fwd auto and a 92 laser awd turbo 5spd. and the eclipse smoked a pole at 40mph and the turbo motor runs good. and the laser has a blown turbo motor . but now for the question will the eclipse motor bolt in no problem? i kno ill have to use the lasers flywheel and such but will everything line up and hook up in the car?.. its more than likely an idiotic question but i figured i would ask before i dive in. Thank you much nice site and veary nice cars
It is the same motor... if on the inside of your door it says early 92... then they are both 6-bolts, and should swap fine (except the tranny's will be different) (awd - fwd)
if the date is late 92 then its a 7-bolt and I'm not quite sure if the motor will fit...
