Maglin
- 872
- 14
- Apr 30, 2004
Wichita,
Kansas
kpt4321 said:Do I pass or fail?
I say Pass. You know you shiizznit...
Streetwize said:Looking at a 91 AWD (sight unseen many miles away) but it smokes on decelleration, says it's the turbo bearing which I assume gets fed/lubed/cooled from an oil supply line. The reason for the smoking sounds feasible (if the rings and/or guides arent the reason, how likely @ 101K miles) and even if it needs a new turbo good excuse for an upgrade![]()
I wonder if there's any members near the NY/PA border that can look at it for me?
That damned thing strips so easy it's not even funny. I think the head was made out of butter and not aluminum on that side. The DSM vendors should start selling helicoil kits specifically for this fitting.Aikouka said:I stripped my threads because I wasn't careful enough, and had to install a helicoil because of it.
Streetwize said:Aikoka,
Here it is, it's in Johnson City NY:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=6214&item=2482314797&rd=1
Thanks,
I think i'll limp it home and put it on my lift to see before I drop the cash on the clutch.
kooka said:most a stock 6bolt has ever taken so far 550Whp. Most I've ever heard out of a 7bolt is 453Whp.
In stock form, I can totally understand the craze with the 6bolts. When it comes to building motors however, a 1g 7 bolt is superior IMO.
