2G new set or rims
DSM_GSX01
984
15
Jul 27, 2011
La Junta, Colorado
Help with buying new set of rims. Want to stay at a size 17' rim. Also want the widest tire on 17' possible. And a good offset also. Been doing resurch and 235/40/17 is biggest i can go. So help on rims and tires plesae. Any input is great. Will be still looking at different post.
I just purchased xxr rims 17x8.25 and the tires I have is 235/45/17 it rubbed a little in the back because of the wide rim but I had the inner fender rolled and all good now. Grips and handles good on turns also the offset is +35, barely pokes out in the front lowered on tein S tech springs
Here's a few pics. Tha last pic is the how much the front tire pokes out. Sorry if pics aren't as clear they are taken with my phone
Ok thanks. Can you go with a deeper offset like 40 without rubbing?
Also could i run a 17x9 rim? Looking for max i can go.
You can go as wide as you want just depending on the work you want to do on the body to roll and pull fenders. You mean lower offset like +25? Max I seen people go without all the fender work is about +30 or +35 and how low you want your car
So you know the smaller the + offset the further the wheel will stick out toward the fender there is + and - offset wheels so a +40 offset will tuck further under the car then a +25
Ok thanks. And yea i was going to roll fenders anyway. I have a stock suspension also. Might just wait and do coal overs after.
So what is the rim size i would be ok with. 17x8.5 or 17x9?
I run EVO Enkei rims and run both 235/45 and 245/40 tires. I believe they are a +38 offset. I only needed to lightly roll the rear fenders to prevent rubbing. I am also at stock ride height. Check out my profile for the White 2g for pics (the ones on pavement).
Yea those were it. They look good. Want to see a set on my car. I want more offset out or the bigget tire i can possibly run.
Thanks. How wide is that tire?
What is your question referring too?
Rim width? Evo 8 Enkei is 17 x 8 +38
A particular pic? Still shots on pavement are 235/45/17
Shots on track are 245/40/17 on same type of rim. (I have multiple sets as they are cheap to get a hold of.)
GofaST4life has 17x9 +35 with 255/40/17 tires with about a 1.5-1.75 drop and only rubs when he makes really hard turns. I am looking to go this route when my tires are used up. His car looks like a beast.
Something like that is what i would like to get. 17x9 and 255/40/17. Do you have any pictures of how the wheel look one side when you look from back or front?
