New scm50 install...18psi? No MBC?
slickster
90
Jan 3, 2003
Cordova, Tennessee
I just installed my new scm50 and with no mbc installed i am getting about 18psi from the straight connection? Does this mean something is binding or is it possible that these wastgates are set that high from the factory? I had to clock the turbo just a bit to clear an engine mount and the wastgate isnt really centered coming out of the diaphram.
So either way, i want to run about 22-23 psi. Should i not worry since i am going to run higher psi or will this have some long term effect and i should fix it..(assuming 18psi is possible on stock pressure scm50) Thinking maybe it might wear out the wastgate really quick or something?
Thankx in advance,
-Slick
How about this question? What range of psi is capable with a scm50 just using the adjustable wastegate arm?
