New personal best 9.50 @ ........ 120?
11secDSM
749
9
Sep 8, 2003
Collegeville, Pennsylvania
Took a trip to the track last night on the hurt motor and ballooned converter and hoped for the best! After the second pass, the converter is done! BUT the car went a new personal best coasting before the 1000' to a 9.50 @ 120. 5.95 in the 1/8! The pass was on e98 and 33psi.
Can't wait for my Bradco to show up!
As for the hood...time for some better pins. ROFL
[ame="http://youtu.be/tEyO6qIwTjQ"]http://youtu.be/tEyO6qIwTjQ[/ame]
Didn't you balloon one previous then you are ballooning this one as well? Could it be a problem with the setup.
It's the same converter. New one is on order. Trans is shimmed to add some converter free play. This was only meant to be a band aid to get the car to the shooutout but after checking all the bearings after the SO and seeing that they were all mint (mainly thrust bearing) I decided to take one last wack at it.
Have you dyno'd your current set up? 9.50 and costing at the end is sweet I wonder what it would of been all out?
We made 725whp not too long ago at this boost pressure. Probably would have been a 9.0 pass roughly...possibly could have hit 8s. Hard to say since i let off before the 1000' mark so that number isn't exactly accurate.
  • Wanted 6 bolt NT water pipe
    • chrisman287
