ECMlink New motor and extremely rich
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
Have a new motor with good compression and no boost leaks.
I have been working on my ve table and cant get it to line up in boost. Had values as high as 107 and still hitting 10 afr on e85.
I dont have log to post currently. But even if its a 60 percent throttle pull ill hit 10s at 15psi.
I recalibrated global fuel to get things back to a reasonable range with link tools.
Im just kind of clueless why under boost id have this issue now.
Now you need to lean out the ve table in the boost range that is way to rich. You are running SD aren't you enriquez?
Lower those numbers and ones around it and use the sdveadjust to let Link help you.
did some adjusting and now my ve table is looking better and im getting closer to my targets!! Had to pull a bunch of fuel with the new compression
But you are making progress!!! Good job. Sometimes you just need someone else to tell you what you've been thinking or trying is correct, to confirm you are heading in the right direction.
Keep us updated! :thumb:
Pretty much lining up spot on.. now i need to add some big timing!
