Running EXTREMELY rich
Boosted DSM 32
681
3
Aug 21, 2011
McDonald, Ohio
Ok guys so my car has been running SUPER SUPER rich lately, its always ran a little rich since i got it, but lately if i give it any real gas at all all you smell is gas and its terrible... when i get out of the car it smells like i was just riding a dirtbike or something LOL Also when i go to start it, it takes like 10 seconds to fire up and when it does it shakes for a second when it fires up (im guessing because of the misfire) Also if i build boost and let the bov go off and keep it in neutral the car will want to stall out yes the bov is recirced and maf is plugged in and everything is tight and hooked up correctly.. The car idles good just when i give it gas it smells horrible
I have all stock fuel system on right now as well
I went to pep boys and got the car read and it came back
1. 2 bad oxygen sensors
2. misfire in cylinder 1
3. some type of fuel problem (i cant remeber what its called)
I changed the spark plugs are the wires are new and it helped a little bit with it running bad but still doesnt feel right when you floor it you can tell its not firing correctly..
Before i go and spend 130 dollars on oxygen sensors, is the sensors whats causing all of the problems? or is something else bad that is making the sensors read wrong and screw up the whole fuel system? If anyone could help me out id really appreciate it! And sorry for so many tech posts but my car has a ton of issues :banghead: and im just trying to knock them out one at a time
Check plugs, and wires, i had a bad o2 and my car idle ok, how is it tuned if at all. o2 sensor was 60 bucks 130 i never paid that much for one. Any vacuum leaks, did you do a boost leak test, might as well.
the plugs are brand new i just bought them yesterday and the wires are new also and i was talking 130 for both sensors it came up that both of mine were bad.. And there shouldnt be any leaks because im all stock everything but i will try a boost leak test this weekend
What's the a/f ratio at idle? It could seem to be idling normal but be stuck in open loop and never going to closed because of bad primary o2.
My one friend that is really big into dsm's and is the main go to guy around here for work told me that i could possibly have a bad valve or piston ring? i dont think its a ring because the spark plug doesnt have any oil on it and it doenst smoke at all the spark plug in cylinder 1 is just extremely black and the smell of fuel is horrible should i do a compression test?
Please let me know if you find the culprit. My car is running really rich too. Fouling out plugs within half an hour of running. I'm leaning toward a 180 out cas, or my ecu is crapping out.
If my "go to guy" thought a rich condition can be caused by a bad valve or piston ring, he wouldn't be my go to guy anymore. Start with the oxygen sensors and go from there.
The reason he said that is because there is a bad misfire you can hear coming out of the exhaust he didnt say that was why he just said i should do a compression test he also said to get the oxygen sensor changed to see if that helps first
A bad valve could cause the misfire. A ring would have to be pretty FUBAR to cause misfire.
Ya thats why im saying i didnt think it was the piston ring it doesnt blow smoke or anything at all im trying to sell the car at the moment to pick up a 1g that has a better body the rust on mine and some other things are starting to get on my nerves and ive had the craving for a 1g lately
Buy a 6 dollar can of cleaner and clean the 2 sensors before you waist 130 bucks its probably why you are throwing a check engine light bc you are running rich mine did that when my a/f was in the 9s.
Are you always rich or just at WOT? I'm suprised nobody mentioned a boost leak. You will run rich if you have a boost leak on a MAS equiped car. Air is being metered before the turbo and escaping before it enters the motor. Try a boost leak test. Thats the first thing I would check if a MAS-equiped car is running rich out of the blue.
The car has always run rich ever since i had it, it just recently got alot worse.. and i dont know exaclty how rich because i dont have a wideband yet
How do you know how rich the car has been running? Are you constantly pulling plugs to "check" for this condition?
I would say you answered your question in the first post. Replace the primary (upstream) o2 if you know it has failed.
Autozone carries a denso o2 for right around $50.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
