New Logger 1st Log ?
BOOSTING_GST
77
Sep 13, 2004
CHICAGO, Illinois
I just did my first log with my new knock sensor since my old one was dead.
RPM KNOCK TIME INJ D/C 02 AIR FLOW
1500 0 5* 11% .98 0HZ
2000 0 5* 17% .96 0HZ
2531 1 8* 25% .92 0HZ
3031 0 13* 34% .86 0HZ
3500 0 14* 42% .88 0HZ
4000 0 15* 51% .86 0HZ
4531 0 16* 59% .80 0HZ
5062 0 16* 67% .75 0HZ
5468 0 17* 73% .06 0HZ
6093 0 18* 84% .00 0HZ
My knock looks good but why would the air flow be 0 hz all the way threw.
I did a diagnostic and it marks air flow sensor could this be why air flow is 0 hz :cry:
and also at 5468 my 02 reads .06 dats not right is it. It some times bogs out at about 3000 rpm. I changes it air flow sensor with another one i had laying around and still the same. I check the harness and the voltage is good. what could it be. Well besides that how does my log look. Thanks in advance. :thumb:
Deffinitly need to get that air flow sensor fixed, if the car can't see how much air is coming in then it can't aid the right amount of fuel, Your car is probably in "safe mode" right now.
The thing is I changed the air flow sensor from my gst and still same outcome. what could it be. Check the wires its all good. First the knock sensor now this.
