new log, need advice
swarm
DSMtuners Server Guru
466
Mar 26, 2004
Spokane, Washington
just got my first real log today
mods are:
14b - 13psi
1g bov
bpr7es
k&n
mbc
taylor 8mm wires
bnm fpr
walbro 255 not rewired
2.5catback w/flowmaster 40 series
no resonators
Code:
RPM	tps	O21	timing	O22	Load	ctemp	STFT	LTFT	spd	airtemp	iafr
1828	13	0	26	900	11	195	17	3	0	84	0
1828	25	20	26	880	11	195	17	3	0	84	0
1772	55	0	21	860	35	199	17	0	1	84	0
4704	64	100	18	860	54	199	0	0	17	84	0
5352	70	0	21	940	14	199	0	0	31	93	0
5352	70	100	12	860	85	203	0	0	39	84	0
6516	71	80	15	900	80	203	0	0	50	82	0
4780	71	0	19	960	10	203	0	0	59	91	0
5244	72	160	10	860	83	206	0	0	65	82	0
5728	72	80	11	940	81	206	0	0	71	80	0
4304	13	0	33	960	19	206	0	0	75	91	0
3816	13	0	33	940	5	206	-4	3	67	89	0
3424	13	0	33	820	5	206	-4	3	60	87	0
3136	13	0	23	0	6	206	0	3	56	86	0
Any issues?
when i floor my car, i don't get 100% tps..
i can only get the logger to read 100 if i pull the throttle cable under the hood manually
so i guess i need to adjust the pedal somehow?
Try to log as few as things as possible too. If you are going to do WOT logs, I would suggest just having o2, rpm, and timing the only things being logged. That way you can more accurate data in the logs.
