new log as requested, 2500-redline
swarm
DSMtuners Server Guru
466
Mar 26, 2004
Spokane, Washington
Code:
RPM	timing	tps	o2 (mV)
2648	33	18	660
2592	33	16	140
2528	33	15	580
2460	32	15	820
2492	24	70	940
2668	20	70	940
2900	14	70	940
3212	11	71	980
3556	9	72	980
3988	10	74	980
4392	10	75	940
4764	7	75	960
5188	7	75	960
5436	6	75	920
5672	3	75	920
5832	3	75	920
5960	6	75	900
6124	7	75	880
6312	6	75	880
6472	7	75	840
6596	7	75	860
6652	7	75	860
6772	6	75	860
6844	8	75	860
6968	31	13	700
6712	38	13	680
6508	38	13	700
6284	38	13	700
6084	38	13	700
5904	37	13	600
5736	26	13	0
5572	26	13	0
5408	25	13	0
5208	24	13	0
5124	24	13	0
14b, 17psi, mbc, 255 non-rewired, 1g bov.
Here is the new log as requested.. 2500-redline in 3rd gear. thanks for any help. I changed the o2 sensor from before and now it is reading better I think... it's in mV. For some reason the TPS is not reading 100% when I put the pedal to the floor, but if I pull the throttle cable at the TB, it hits 100. i need to figure out how to fix that.
There are two bolts at the back of the intake mani that can be adjusted to take the slack out of the throttle cable...try that to see if it helps.
Edit: untill you can do a log and read 100% TPS I won't say anything about your log. Right now it looks rich in the middle for sure.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
