New Intake Manifold
If i remember right, Mike wasn't using a Forrester intake in that pass
Hogan SMIM V3 and MAGUNS CAST beats it. I have run all three on street to drag to standing mile car.
im pretty sure he was. Every record Mike broke if i remember was with the Forrester. I seen a dyno with Alberts aka DV/DT Fabrications manifold which looks like a better design than them all but topend only made 12hp more than the FRH around 750whp. But made significantly less mid and lowend power.
No. By being a barrier the phenolic spacer creates less heat to the head. It transfers like 8-10 times less heat. Look at it as a mini heat exchanger instead of just a spacer. Less heat = More power. It has a purpose.
but above your post says
"have wooden phenolic spacer CNC'd and welded..that's what i meant, you now have the forrester with no wood between halves and it's welded together solid
"have wooden phenolic spacer CNC'd and welded..that's what i meant, you now have the Forrester with no wood between halves and it's welded together solid
oh yeah. that was a prototype that was never finished. Mines is as close to what it would have been that there will ever be. But... you just never know :sneaky:. But I do know it was tested with the spacer on low boost and it outperformed a regular Forrester across the board. I gave Mike the FRH in post #1. Maybe if he doesn't use it anytime soon we can do a back to back comparison against mines. i'll ask Devo2ning cause mines doesn't leave alot of room and is time consuming to take off . But they wanted to compare them a while ago. It would be an awesome test!!
