New injectors, Throttle body, fuel pump N/T
RyanJ
70
Apr 4, 2006
Wheeling, West Virginia
I have a N/T 1g eclipse and I heard that the Injectors and fuel pump from a turboed 1g will fit into my car. The injectors in it now are stock 240cc and the turbo ones are 390cc I believe. If I put those in , a fuel pump from a turbo 1g, and I wanted to bore out my throttle body 1-2cm. Will this make my car run too rich? If so what do you suggest?
Just an add on will my friends 2g cams fit my car and will they help the performance at all?
find a set of 91-94 tsi cams and swap those out, I did and i noticed a fair gain. Its a cheap way to put on a few more HP. If you get to froggy and spend alot of money on a n/t you could have bought a Tsi for the same price, thats why I stopped spending money on mine and began to look for a Tsi
The compression in the pistons is too high to get any use form a turbo and to make it turbo ready would take tons of stuff. I was led to believe that my ECU would correct the air fuel ratio. Should I maybe get an AFC?
I got my N/T with 72k miles for 2900 and it runs great and the interior is really nice. Turbo cars are so hard to find where i live, West Virginia, that when you find one they are tons of cash. I was just looking to add about a few HP you know cams intake easy stuff just to get alittle more balls out of it. Its still my everyday driver.
Thanks for the suggestion on the cams thats what I was thinking about doing. But if my buddies would have fit that would have been way cheaper.
