J-Syght
- 110
- 0
- Oct 14, 2003
El Campo,
Texas
okay i took out all my bolts so i paint my cover, but the thing is the valve cover won't come off, i took off all the bolts it's kinda tight. Any ideas please?
As a last resort. "Very, very, very, very gently" and "large flathead" being the key words. Find the widest one you can. But first:"Very, very, very, very gently, with a large flathead screw driver, pry it up." - kyledykstra
Use this method as Plan A. Tap several places all the way around the cover if need be. If it somehow does not work, make certain that you have indeed removed all bolts and any remnants. Then try the other procedure. You can get a valve cover pretty cheap. A gouged head is difficult to repair and expensive to replace."small block of wood, and a hammer.... knock it on the front right hand corner and consider it done......" - Strm Trpr
J-Syght said:Why do i need a new gasket, the one i took off looks pretty much new still?
No, no, no, no, no.Diplomat said:When you replace the cover, go slow and use a torque wrench for gods sake.
