New head gasket now car seems like timing is off
Dustin269
Jul 6, 2011
Niles, Michigan
Just replaced the head gasket on my 95 gst now it seems like timing is off but all marks are lined up anyone know what might cause this?
Was not aware of marks on the valve cover and the symptoms are sputtering shaky engine car won't drive with out jerking
are the cams lined up with the valve cover...?
went out to look and i noticed something was in the back side of my intake cam gear it was part of the cam sensor so in a way im pretty sure you helped me fix this :hellyeah: just got to get new sensor and find out
The timing marks can line up to the naked eye, but the cams need to be lined up with the slant of the head. There's a special tool you can look up, it goes in between the cams to lock them in place. (where they should be). I had this problem and it was a tooth off. Shitty idle.
