New from El Paso
yeah if you end up re painting it you should keep it that color and the gold rims im lookin to get gold for mine too
Yeah i know i might just keep it this color and i am gonna keep the gold rims i just need the wing. Im ordering everything off Ebay but i will post pics of my progress.
what you guys think??
<a href="http://s1021.photobucket.com/albums/af333/PERFECTIONS_01/?action=view&amp;current=ec6.jpg" target="_blank"><img src="http://i1021.photobucket.com/albums/af333/PERFECTIONS_01/ec6.jpg" border="0" alt="Photobucket"></a>
So I just found out I need a clutch for the car... The one it came with berly even lasted me to only test drive car after new tires. Anyone know any good places or sites for clutche's??
so my gears grind. i try doing what people told me like "bleeding the clutch" to take the air out. Which i did it had a-lot of air. BUT the gears still grind i don't know what else it could be. Some say the clutch is giving out then other say i need to adjust the clutch because its not "engaging right"? And someone said clutch cylinder?? i would greatly appreciate help i hope its not the transmission.
I'm not that familure with the 420a but check out this thread, it looks like it has everything you need. httphttp://www.dsmtuners.com/forums/420a-bolt-tech/374258-how-change-tranny-oil-what-use.html://. Make sure you use ATF+4 fluid in your NV-T350 trans
he's car is standard so no ATF+4....he uses the same as turbo editions
all eclipses RS, GS, GST, GSX, AUTOMATIC USES ATF+4 OR DEALERSHIP YOUR CHOICE and on stardard all models use Gear oil 75w-90 or dealership your choice
Actually Chrysler recommends ATF+4 for the NV-T350 MANUAL transmission.
VelocitàPaola;152245283 said:
I deleted some posts because there was some serious misinformation in them. Please remember rule #3 before posting: "Don't try to help if you don't know the answer - bad advice is often worse than no advice."
The 4G63 is not the same as the 420A and regular gear oil will not work in the NV-T350 manual transmission. Pennzoil Synchromesh works (I have it in my tranny), but New Venture Gear, the manufacturers of the NV-T350 only recommend either the Mopar NV-T350 specific fluid or Chrysler ATF+4. If you use anything else, the results aren't guaranteed to be good.
Not directed at me, but I'll answer anyways. :)
It is true, Scott. The paper backed synchronizers are the reason for the special gear lube, to ensure longevity. ATF+4 officially supersedes the special Mopar fluid since they stopped making it, and is officially the only recommended fluid. Other fluids may or may not work, but we tend to err on the side of safety when recommending fluids to people.
I am currently using cheap-o $2.50/qt. store brand ATF+4 in my NV-T350 without issue.
The first thing that comes to mind is... RUNNNNNNNNN away from that car. But if you like it good luck to you sir. Be prepared to spend over 10,000 to make it look stock and clean
Mega u pull has the tail lights and rear bumper, you have the headlights, but might be a pain to find front bumper and door caps without paying arm and leg. Took me about 2-3 weeks to find the front bumper in town. Let me know if you need help finding anything .
i just did a quick simple google search and found the bumper new for 40 bucks in some warehouse down central paso. :)
address please!!! :) i try google it but couldn't find it :hmm:
I think I know were are you talking about is it certifit...cause I got my fender there for like 50 bucks new and I saw there catalog online and they have the bumpers new for 40 bucks
Where at?? :)
hey guy's i was wondering if i should replace the Slave Cylinder???
maybe that's what's making my gears Grind?
what you all think?
