96gstdsm
- 808
- 2
- Aug 7, 2006
monroe,
New York
Just got a big ssac fmic installed. I am now having some cooling problems. When I am stopped or going slowly in traffic etc the temps are around 210* or so. For some reason though when I am going on the highway just cruising the temps go up as high as 230*
Shouldn't it be cooler on the highway? I always figured that the cooling problems would be when stopped or going slowly. Could this be another problem? The thermostat was replaced I know. What temps are safe or unsafe? Could it be that I just need to bleed the coolant system and refill? What is the deal with the mod of drilling a 1/2" hole in the thermostat housing? Anything I can check before I assume it is just not getting enough air somehow on the highway? Obviously I am aware that the fmic is blocking a lot of air, but from my understandings most people don't have any issue on the highway. Traffic I can understand more but not when moving with all the air coming up from underneath and all. Also the temps when on the highway go up and down for some reason. Like from 218* to 226* about. The stock gauge shows it going from just over the middle line to about 3/4 the way to hot and then just back down again and repeats. My logger shows that the temps are changing as the stock gauge changes also.
