New car. Finally got a TURBO!
badabing33a
788
Oct 2, 2008
Louden, New Hampshire
im selling my car and i found this 91 Mitsubishi Eclipse GS for $1500. The rims and tires are aftermarket low profiles, has a carbo fiber hood, a hipo chip for little more fuel for the turbo, the tranny is setup for racing where high gear 4th comes in at 100mph so this car is geared for 140mph, internals of the tranny are all new with heavy duty valves and pump for duribility, the lower end has 77mils, the cyl. head was reconditioned and has around 6k on it, has a front mount intercooler, and the turbo is upgraded. so, what do you guys think? worth $1500? :dsm:
If you can get your hands on the car, check for rust, see what other upgrades it has (exhaust, cams, turbo), check out the turbo shaft play, check compression, check the interior, etc., and take it for a test drive.
If it all looks okay, I'd certainly buy it for $1500...if I had a 3-car garage, that is.
Looks like a pretty good deal for $1500 assuming everything checks out ok.
I'd also check for rust and at least run a compression test to make sure the engine's ok.
ok i will have to do that. thanks guys. also, the guy had reconditioned the double overhead cam. on one of the pics you can see the aftermarket muffler. right now i almost dont give a flying dsm if it has an exhast or not. as long as everything else goes fine. besides, i need something to upgrade! LOL
