Need your opinions on tranny issue...
ProjectTalon130
365
Jul 16, 2003
G-bury, Connecticut
Recently my tranny has been grinding every time practically while shifting into second, goes every time into gear but the synchro is grinding. I am about to change from Amsoil 75w-90 gear oil to Pennzoil Synchromesh, I'm hoping this will work. What is strange is one night at the mall I decided to romp on it and shift quick as I could from 1st to 2nd and didn't grind one bit...3 shifts in a row!!! But now its doing it again and did it after those 3 random times....it even grinds into 2nd while downshifting from 3rd....what do you think will need to be done now??? I'm thinking rebuild but I try to not think that b/c its so much $$$ for one stupid synchro..the gear is fine...stupid synchros....I'll keep you all posted if the Synchromesh does indeed perform a miracle compared to the Amsoil. :boring:
yeah, I had the same problem. All i had to do was have the slave cylinder adjusted and problem solved. :thumb:
would it only do it in one particular gear though if that is the culpret??? Seems like every gear would grind if that were the case...
P.S.- what did you have to do to adjust the slave cylinder???
