kicknyours
- 40
- 1
- Sep 13, 2004
Egg Harbor Twp.,
New Jersey
I'm currently just about done pulling a motor to build while my stocker is running as a my daily driver. Any input or opinions (whether critical or not) are appreciated...
As far as the below, It is what i currently have or have planned on getting. I regards to gauges, I'm not sure but have been reading about the truboost from AEM and had planned on an oil, air/fuel(?), and egt gauge. Any thing that you'd recommend please let me know (models/brands/ect)(i know "getting a new blowoff valve" is one of them)(also things that i missed)... Thank you in advance for your time...
My '97gs (soon to be gs - T)
(* means i own it, but not currently installed)
Engine
Bottom End (not installed)
Dodge / Plymouth /Chrysler Neon 2.0 SOHC and DOHC Engine rebuild kits
Taking block to machinist
*JE Pistons & Rings
*Eagle Specialty Forged Rods
*Rod Bearing Set (Mopar)
*Main Bearing Set (Mopar)
*Oil Pump
*Water Pump
*Oil Pan Gasket Set (includes rear main seal)
Top End
Concept Illusions Head (not sure which one yet or if getting new cam shafts - not sure if i want rough idle with higher model depends on the imput i get back)
link to stage 3 head
CI Stage 3 Head Eclipse/Talon 420a - Staged Heads - Engine - 95-99 Non Turbo 420a - Mitsubishi - CI Motorsports
link to stage 4 head
CI Stage 4 Head Eclipse/Talon 420a - Staged Heads - Engine - 95-99 Non Turbo 420a - Mitsubishi - CI Motorsports
Other (installed already except for *)
Ported & Polished Intake Manifold
55mm Throttle Body (from CI)
NKG doulble iridium plugs
Adjustable Cam gears
Optima Red-Top Battery
*New Timing belt and tensioner (from Parts Dinosaur)
*belts
*Turbo Kit
Hahn Racecraft Stage ll
Front-Mount Intercooler (Mandrel Bent, TIG welded)
Intercooler Piping (black-gloss powder coated)
Silicone Hoses & Clamps
Hahn Super 16g Turbo
Turbocharger Wastegate Actuator (for Higher Boost pressure)
Exhaust Manifold (Cast Steel - Upgraded from earlier tubular design)
Downpipe (Ceramic coated, mandrel bent 2 1/4")
Air Piping (Mandrel bent, TIG welded, black powder coated) 2" compressor outlet, 2 1/4" intercooler outlet
Blow off Valve (Standard, OE 300gt)
Cold Air Intake (Foam element w/ mandrel bent piping)
*Fuel System
(Currently)
Hahn Complete System (part of Stage ll Kit)
Fuel Pump
Injectors
Regulator
Hoses
Fittings
Lines
Electric Mods
(Plan on Getting)
Hahn Port Fueler
(for some reason i like the simplicity of it... I haven't heard anything really bad about it other than people that don't have it, haven't tried it, or love their own setup (which i can respect). I already have four fuel injectors from the turbo kit so i'd either get the port fueler with out the injectors or just order em (if they're different) and sell the ones i have (never used). Also, i could be wrong, but if i get the portfueler (which i plan on) would every part of the stage ll system still be used? (sorry, i'm ignorant.)
Exhaust
High Flow Cat
Apexi N1 Catback Exhaust
Suspension/Wheels/Tires
Front Strut Bar
Tokiko Illuminas (5way adjustable)
Springs (1.5in drop)
Full Camber Kit
New control arms
Drilled and Slotted Rotors
EBC Green Stuff Brake pads (upfront)
Enkei GTVs (18in)
Have new Falkens... forget the type...
With all of the above I believe that i'd have a pretty good car... one that could at least make me grin. what do you think. i'm looking to complete this after winter... thanks again
Engine
*JE Pistons & Rings
*Oil Pump
*Water Pump
Top End
*belts
*Turbo Kit
*Fuel System
(Currently)
Fuel Pump
Injectors
Regulator
Hoses
Fittings
Lines
Electric Mods
(Plan on Getting)
Hahn Port Fueler
Exhaust
High Flow Cat
Front Strut Bar
Full Camber Kit
New control arms
Enkei GTVs (18in)
and if not, he'd lose a customer for life...
ha
