need vendor selling oem bolts
636chris
153
Aug 15, 2009
philadelphia, Pennsylvania
i need motor mount bolts for a 90 awd 5 speed Not the ones that hold the mounts and brackets to the block . I need the ones for mounts to frame , bracket to mount , and cross member to frame (passanger side). basically all of them except those that hold the brackets to the block.
i have been searching this for two weeks now, site after site. so please dont post a link unless the vendor has the correct bolts. Hardware store is really a last option here and rather confusing for me to find the exact bolts i need. id really rather have the oem bolts or oem replacements. id even be willing to buy used if i could find the damn things
RTM could order you anything that the Mitsu dealer network carries. In fact, I'm guessing a number of this site's supporting vendors could do the same. For that matter, pretty much any Mitsu dealer could do it. I guess the trick is convincing one of them it's worth their trouble. If you want, I could post some of the part numbers and you could contact any of the above and see what they say.
Your best bet is to download and install CAPS/ASA, and find the part number for the bolts you need, and then order from the vendor of your choice or the dealership. http://www.mitsubishilinks.com/
Or, you can look at the screenshot, pick the ones you need, and I'll get the part numbers you need. Then you can order them from the vendor of choice.
**NOTE** These are NOT the actual part numbers.
Just in case anyone else is looking for the numbers, who don't have, or can't download CAPS/ASA; here are the actual part numbers for the bolts I think you're talking about. If you need more just say so.
You guys are life savers I'm gonna get to work on calling jnz tomorrow . Part numbers are great and help a ton. By chance does anyone know what bolts it any work in my situation from a nt 2g.
i just have to get the time to sneak away from the family for a bit and pull my mounts and parts out and figure out exactly what im missing . i will update as soon as i can it may not be until the weekend . again thanks to all that replied. if anyone is local that could give me a hand that would be great . pm me for my cell number
heres what i have so far . i know the one bracket is for power steering which i deleted , and the fog light bracket, and of course the mounts . i know i need motor mount bolts , trans bolts and t case and starter bolts . thers also seven m8x1.25x40mm bolts in bags from lowes some are threaded all the way others arent. can anyone identify whats left in the picture and give me the part numbers to what im missing . i will spread rep to anyone that can help me out
heres the second pic
These are what appear correct to me off hand.
1 - MB175769; driver side engine mount through bolt
2 - Depending on size, they are either MU430002, (2x) driver side engine mount nuts to engine bracket (front) or MF430123, nuts for #1 and #8.
3 - MS440504; (2x) nuts to secure #1 in place
8 - MF104927; transmission mount to frame bracket through bolt
10 - MU240026; (4x) air conditioning compressor mounting bolts
The rest I am not completely sure what they are. What you can do is measure them and let us know the sizes along with any other physical characteristics and we can find part numbers for bolts similar to what you need.
4 looks like starter bolts, 5 looks like a timing cover bolt, 6 looks like a power steering mounting bolt, 9 looks like throttle body bolts but the fact there is three of them says fuel rail..
7 could be a number of different things but nothing pops to mind in the general vicinity of anything else mentioned here unless one is a stud with a nut rather than a bolt.
thanks for you help. 7 is bolts . i have a whole box of smaller bolts also LOL . stud with a nut you say , where would that go ill have to look
If it is two bolts, forget I said anything about a stud and a nut. I suppose they could possibly be fog light bracket bolts, but its been so long since I've looked at those I cannot recollect their size.
ok so i think i narrowed down what i have left to find.
front motor motor bolts ( i have the engine bracket already mounted on the motor)
rear engine mount thur bolt and nut
trans motor to frame ( i found two nuts , dropped the third in the frame at the junk yard)
trans mount to trans bracket bolt and nut
passanger side cross member bolts (all of them)
starter bolts
alternater bolts ( i have the top bracket on the motor) i may just get a br or jays relocation bracket and use the saturn alt
  • Wanted 6 bolt NT water pipe
    • chrisman287
