Need part numbers for oem rod and main bolts
stutz43078
100
Oct 14, 2009
Urbana, Ohio
If anyone has them it would be great. I've tried searching myself, but no luck. Please don't just say buy arp's because you will only be wasting your breath and everyones time. Almost forgot, it's a 6 bolt. Thanks in advance :)
(8x) Rod bolts: MD040553
(9x) Main bolts: MD000235
(1x) "Other" main bolt: MD010037 (top threaded for oil pump screen support)
If you don't want ARP's the go to you local hardware store and get some grade 8 bolts or studs and pray they hold up. Everyone does the ARP ROUTE FOR A REASON! I just did and it just makes sense.
Do you happen to know the part number for the nuts for the rod bolts? I assumed they would come with it but appearently I was mistaken. Thanks.
(9x) Main bolts: MD000325
I know this is old, sorry for bringing it back from the dead. I just wanted to correct this post as the part number for a 6 bolt main bolt is wrong.
For future search results, the part number is: MD000235
