Need to tow AWD- how?
Status
Not open for further replies.
nickrule99
502
Jun 14, 2003
Greenfield, Massachusetts
I need to rent/buy a harness to tow an AWD.
I was going to rent one of those dollies from Uhaul, but I remembered it was AWD.... I would much rather tow the car with all 4 wheels on the ground as apposed to a full trailer, but any suggustions would be good.
Anyone know where I can rent one? or what to ask for it I end up needing to buy something?
The truck Im going to be pulling with already has a trailer hitch, so Im all set there.
-Nick
i dont understand, why not just a full trailer? if i remember it was like 34 for half a day.
If you're going to be doing this for any significant distance, you should just get it flatbedded there. But if not your cherokee will be fine.
i was in the same situation last week.
UHaul has something that gets all 4 wheels off the ground. Its called an auto transport. Its about the same price as the dolley ($50) If you don't have anything to pull it with, just use one of their trucks. ($20+ .40 each mile). Don't forget you have to pay for gas as well.
I moved my 95 gsx from grand rapids to chicago for about $350..thats a 4 hour, 300 mile drive
Thanks man, thats what I needed.
Ill be towing about 400 miles, so Im gonna just get the trailer. I think the Jeep should be fine, especially since its basicially all highway. Ill just have to keep it around 65 and remember I need to slow down a hell of alot sooner.
They won't let you tow with the four wheel carrier unless you have at least a class III hitch on that Jeep. Otherwise, you'll have to rent one of their trucks.
The car hauler that uhaul rents weighs 2,000 lbs, so take that into account. If you're going to rent a truck from uhaul to tow it, their normal GMC 1500 series trucks won't do it - at least they won't loan you both. They will, however, loan you a 14' truck + trailer. Same price as the full sized pickup, but the mileage is worse.
I was quoted $45 for 1 day with the trailer, and $29 + $0.79/mile for the truck, two weeks ago. Since I was towing the car 70 miles each way, it was easier to just get a tow company to handle it with a flatbed.
u CAN tow it with a jeep grand cherokee. I know from expereience. I towed my totalled stratus (heavier than my dsm) with the auto transport. The jeep has a v-8 but ti pulled with no problem.
Excellent. :thumb:
Now Ive just got to make sure we've got a class III hitch, and were golden.
:dsm:
Your stratus is FWD, and thus has no center differential. Whatever you do, do NOT tow an AWD car unless all 4 wheels are on the ground.
WOW! Thanks soooo much I didnt know that. :shhh:
Dude you may want to check up on what you are talking about before you sound like an ass....
The auto transport is the U-haul trailer that gets all wheels off the ground. :thumb:
So back to what I said. You can tow your DSM with the auto transport no problem. Works even better if your truck is 4-wheel drive. :thumb:
out there said:
you mean like it's a fwd?
No, like it was rwd. You still will have the rearend on the pavement, but with the driveshaft removed, it will not engage the transfercase/transmission/etc.
I called Uhaul last night and they told me I could use the car transport if I have a class 3 hitch... which I do. So we're good to go :thumb:
Thanks for the suggustions guys, really appreciate it.
i car caddied my car 900 miles, all i did was completely take out the drive shaft to the rear wheels.
uhaul has a whole car hauler. that will tow your car easy. if you can leave the window down that would help becuaswe i ran into the problem of barely being able to open the door. so i left the key in the on position and rolled the window down to get in and out of the car. and its cheap too.
Just going to jump in here because some people don't seem to be hearing an certain individual. Here are the rules for towing your AWD dsm.
option #1 is to get all 4 wheels off the ground and stationary. This can be done on a flatbed, car trailer, etc.
Option #2 is to remove the drivetrain to the rear wheels. This can be done through the removal of the axles or the driveshaft. This is a viable option and will not cause damage to your car. This is also usually the cheapest option.
Status
