Need to replace my door.
xxShaneOmac
423
Jan 2, 2007
Everett, Washington
Im Looking to replace my passenger door on my 2nd gen.
I went thought some bushes and it pushed in my door pertty much, Window stops 1/2 down and its pretty comseticly bad.
Also took off my side skirt and dented my rear q panel.
But What should I look for. When I open my door it sags down a little. If I replace w/ another should this go away?
What do I have to look for, What would match up to my 2gb eclipse?
95-99 and any talon doors?
Are there any cap peices or things i should look out for?
Thanks.
You may have broken hinges or the bolt on the hinges broke off that is why it probaly sags. The only way to find out is to remove the fender and check it out.
