need to raise back suspension
Rice Over Wheat said:
Are you encountering this problem because you have AWD rear struts on a FWD? BU3533 vs BU3534?
No, the rear is perfectly fine; it's exactly where I want it to be. However, the front is a lot lower than I would like it. It barely clears the speedbumps in the parking lot and it's hard to find places for an alignment.
RamenPride said:
Well, everything was looking good for awhile. I guess now that the rubber's been compressed it's back to about a 1 finger gap.... I'm going to try and re-position the spacers. If that doesn't work out I'm going to cut 1/2 a coil off of stock springs that I got off of ebay for $7
Same problem happened to me after I had put in some rubber spacers. At first I was like yeah, finally its even all around and a couple months later it went a little back to how it was. Cant say it did not make a difference becuase its clearly did but Im thinking of taking out the sportlines and getting some pro kit or even going with another brand in totall.
