Need to get a 2G AWD downpipe
MITSUMURDOK
150
8
Jul 12, 2005
Newburgh, New York
I just scored a Megan Racing catback for cheap and was looking to get a Megan downpipe, but apparently they are backordered everywhere. My current exhaust is rotted and need to put my newly acquired exhaust on. Any ideas on different downpipe that will work with stock O2 housing and Megan catback for about same price as the Megan downpipe?
Punishment-racing offers a nice, $150 downpipe for your AWD, says they only have two in stock though. People have said good things about them. I personally run a megan so I can't really speak to it but just by visual inspection of the photo it looks the exact same...it will eliminate the cat, however, if that's an issue for you, I do not know New York laws.
Try STM too, they have a megan for $195 and it does not say anything about being out of stock. Both the megan and punishment racing will bolt right up to the stock o2
Punishment says the downpipe won't fit the stock o2 housing. I just ran into the same problem though and I ended up getting one of the eBay ones since there are no other ones available at the moment. I would not recommend it though, they are copies of the original megan downpipe which means you have to modify it to fit the o2 housing since its 3" all the way to the o2 housing, and the flange that bolts to your catback is welded in the wrong orientation, so you'll have to modify that as well. I'm going to just cut the downpipe in half and use a butt style slip fit connector so that I can rotate the flange.
