Need specs for some bolts
DanGST
352
Oct 8, 2010
Bronx, New York
I am missing bolts for the thermostat housing, valve cover, fuel rail, and coil pack. Need these bolts urgent so no I cant call/order from far. Plan to go to homedepot and pick them up.
probably a combination of both M8 x 1.25 and M6 x 1.00, not sure of the length. They probably won't have the exact length anyway at HD or Lowe's. If you go to an Auto Parts store they may have a container of metric bolts/nuts/washers assortment. I think I've seen them at Northern Tool and Harbor Freight also.
Over the years i have a box of bolts from dsms, almost anykind from tps bolts, to engine mounts, you name it LOL.
I don't have a box, but I do have a big 'ol bag of bolts and stuff also. I also waste money on nuts, bolts and washers by going to the store and buying what I need and then some. Let's say I need a 40mm 8 x 1.25 bolt, I get like 4 of those when I only need one, and also 4 that are like 35mm long instead. Then maybe some 8mm washers and nuts, also some 6mm bolts, etc. I just like having spares/extras on hand because it's a real pain to break/lose one and then have to go out to the store and find a replacement.
For a 2.4L Spyder:
Thermostat Housing - All are M8 x 1.25 mm pitch flange type bolts; lengths are (x1) 80mm, (x1) 65mm, and (x1) 25mm
Valve Cover - (x6) M6 x 1.00 mm x 20 mm long, with washers
Fuel Rail - (x2) M8 x 1.25 mm x 65 mm long, with washers
Coil Pack - Both are M8 x 1.25mm flange type bolts; lengths are (x1) 25mm, (x1) 16mm
hey does anyone know the bolt sizes for the 1g's body parts? sorry for the thread jack man.
M6 with various lengths like 12mm, 16mm, 20mm, and 25mm. I want to say 1.00mm pitch as well.
