Need some opinions on upgrades for the 420a
IIv SHaDoW vII
369
May 8, 2007
Topeka, Kansas
So far it is lowered with catback exhaust.. Right now Im thinking intake and headers..
I have looked into the obx intake but it requires some tapping skills which I dont have so what other intake could I use, and throttle body as well. Searching provided me with info about a 60mm tb so where could I buy one that would replace the stock one.
Headers I want 4-2-1's I will not go with 4-1 ever again on my car.. I had 4-1 on the GST with little to no difference in power.. not that I was looking for any by replacing them but my friend who also had a gst put 4-2-1s on and it made a big difference. Anyway 4-2-1s for the 420a dont recommend anything else. Although.. I was told since these 420as get hot enough as is, that putting headers on is a bad idea.. is this true.. or are there some headers I can use that will allow me to keep the heat shield.. thanks
Thats all I can think of for now that I have the money to upgrade..
my 420a never got unreasonably hot and i had a header on it but it was a 4-1. I dont think headers in general do much. My friend just got a AEM cold air intake for his and that fit with no modifications and works nice hope this helped
You should really be posting in the 420a bolt-on section.
Get a ram intake or cold intake with a bypass. Headers mainly just shift the power curve. The best thing to get is an UDP.
Venom makes a decent intake manifold, but most will agree that a ported factory IM with knife edged injector humps will support a decent amount of power. I believe Modern Performance has 60mm TB's, but a good cheap option would be a modified Jeep TB. The largest gain to be had from the induction area would be a SRI or CAI. Don't waste big dollars on a brand name intake, though. Get a cheap eBay intake and put a K&N, Dryflow, or foam element filter on it.
4-2-1 tubular manifold are difficult to find, most do go with a 4-1. As mentioned, the gain from a tubular manifold is slim, and the power is mostly shifted. A heat shield is always best, but there are no aftermarket manifolds with provisions for one, so you would have to fabricate your own. Heat is not a very big issue, though, on NA 2gnt's.
http://www.dsmtuners.com/sub.php?page=2gntupgrades
BTW: I like the new avatar.
