Need some opinions on my logs
teamitr
100
Jun 14, 2005
Riverside, California
what can u guys say about this two logs:
RPM,Timing,Air Temp,O2 1 Bank 1
5572.0,16.0,126.0,0.92
7244.0,21.0,129.0,0.02
4816.0,13.0,135.0,0.94
5880.0,16.0,133.0,0.92
6596.0,16.0,131.0,0.92
7272.0,20.0,129.0,0.32
5236.0,17.0,133.0,0.92
5540.0,13.0,129.0,0.92
5944.0,11.0,126.0,0.94
6292.0,12.0,124.0,0.94
6620.0,14.0,122.0,0.94
6880.0,15.0,122.0,0.94
7176.0,16.0,120.0,0.94
7396.0,17.0,122.0,0.1
7724.0,36.0,131.0,0.0
This one was at california speed way last saturday it was about 110 degrees out there
and this was at 21/22 psi.
RPM,Timing,O2 1 Bank 1,
4812.0,26.0,0.86
4848.0,14.0,0.94
5132.0,14.0,0.94
5508.0,17.0,0.92
5916.0,20.0,0.92
6264.0,21.0,0.92
6584.0,22.0,0.92
6904.0,22.0,0.92
This one was today on a quick pass in the freeway at 14.5/15 psi.
BY the way they were both with the same gas that was in the tank wich was 100octane.
the logs you posted are too narrow and too high in the powerband to be useful.
Go do a pull in 3rd gear from 2500rpms to redline all at WOT.
Log the rpm, timing, and o2 bank 1 and report back. Make sure to post the whole log starting at ~2500 not 5000 like the 2 above.
2nd one looks pretty good. First one looked decent just no need to go anywhere near 7k rpm's. And he is on a T3/T4 turbo not the stock turbo so they are pretty useful on that size of a turbo. On the T25 yes they would be pointless. Wondering what size though if you can run 22psi on 580cc injectors.
  • Wanted 6 bolt NT water pipe
    • chrisman287
