need some help: problem after changing t-belt and 1g tb
brute said:
Did you put the tensioner on and watch the marks spring to straight up instead of right next to each other?
edit: your timing looks perfect, BTW
vacuum reading on idle is about -5....
I removed the EGR system completely, could that cause any of my problems? Is there anything that i should leave in (any solenoids or valves)...
ive checked my timing by using timing light, and it shows marks about 1/2" higer than leter T on the plastic cover..without light when align cam marks, mark on crank pulley is on the letter T on the plastic cover
thanks
anyone?
another thing that maybe would help is, if i FREE rev up my boost goes up. Somewhere around 4k rpm my wastegate opens up ( my antilag is not active )
i replaced my t-belt and removed balancer shafts and EGR system , rebuilted my trany...
my engine was completelly out....Now after putting everything back together my idle is so bad, i cant rev over 4500rpms, engine is very noisy.....
BUT after adjusting my timing on the DSMLINK to +12 deg on all of the sliders, my car started to work much better (not perfect yet, but way better)... , i know it sound crazy but from now i dont know what could cause this problem... Ive checked my timing belt 1000 times and all marks are where they need to be...Only thing that i would think of is maybe one of the sensors (crank pos, cas or mas) ... any suggestion would be appriciated
It sounds like you have a major IGNITION timing problem. Your VALVE timing appears to be alright. You do understand the difference, right? Did you properly install the crank and cam angle sensors.
http://www.vfaq.com/mods/wayback/BradBauer/engine/timing.html
No, removing your EGR will not cause this. Have you done a compression test? Who built and installed the motor?
It sounds like you are in a little over your head. Maybe you should have someone else take a look at it.
