ECUflash Need some help from you ECUflash gurus
Racejunkie05
42
Nov 13, 2012
South central, Pennsylvania
Hello dsmers,
I picked up my first dsm about 3.5 years ago and since then I've grown more and more passionate about them. I do all my own work and tuning and I wouldn't have it any other way. My mod list is out of date so I'll update here: 2.3 stroker wiseco/eagle, 272 cams, super 40 with t3 bep housing, 255 rewired with 6an feed. Gm maf and 3 bar map. I'm tuning on pump gas with ecu flash and logging with evoscan. I have an external wideband which I went ahead and pinned to the ecu. Here's my question: I decided to hookup the nlts feature and since I have a 99 blackbox, I pinned 44 on the ecu and ran it to the clutch safety switch. I enabled nlts in ceddy bits and took the car for a test drive. Everything works perfectly, antilag, two step, but when I'm driving and push the clutch to the floor and rev the engine, it goes the whole way up to my normal rev limiter (7700) even though nlts is set at 5300. What am I doing wrong? Any help would be much appreciated.
Thanks
Jonathan
