Need Pictures Please
mitecl96
460
9
Feb 20, 2012
McMinnville, Tennessee
I have been working on changing all my dash lights to Blue LEDs for the last couple of weeks. I have been taking pictures from start to where I am now and almost done.
I forgot to take before pictures of the stock gauge cluster, climate controls, and the cruise/fog/mirror controls. with the nasty looking orange lights.
I am asking if someone can take pictures of these parts with the stock lights on at night so I can have some before pictures.
And please be a non-turbo because I am a non-turbo :cry:
Thanks you a lot if you are able to do this.
Hope this helps.
Yeah I got some still need yo make adjustments to the lights on all the switches still waiting on some LEDs to get here so I can finish the gauge cluster. I do have the needles painted blue and having white lights light them but not liking it with the other blue LEDs so I'm changing them to white needles with blue LEDs. Post pics tomorrow.
Here is the cluster so far. Didn't like the color of the needles lit up so going to try something new so got to wait for those parts to get in before I do anymore work on it.
here is the cruise/fog/mirror. Some lights to dim so going to work on that a little bit. I did a little different than what the tec. article on here said to do on the cruise control. I cut of the tip of LEDs off on the the circuit board and than soldered the blue LEDs where the old ones where. The light that comes on when the cruise control is switch I replaced with a clear LED but for some reason it lights up purple which is still kinda cool.
The HVAC. The A/C switch isn't bright enough I think. Got To work on that.
Decided I would also have my cup holder light up too. I though the light would be bothering at night but it wasn't.
Updated Brightened up the fog switch and the Mirror controls.
The picture I'm sure people where waiting for.
Okay, that is friggin cool. Most interior light mods come out tacky, but that is cool. Literally cool. The blueness creates a frigid atmosphere. Shit I should go write some poetry brb.
Can you still dim them? If so that looks really good. I like the cup holder light as well, that would help out a lot at night.
Thanks, it turned out better than I planed.
And Yeah the dim works perfect. And Yeah the cup holder helps and looks good. Still got a lot of LEDs and looking around for other ideas but not to over do it. Trying to figure out how to light the ring around the ignition.
Figured out a little bit more to change. The cruise, blinkers, gas, and check engine lights. What y'all think.
The ignition ring should have wirering already there for a light. On my gsx it lights yup when you open the door but on my spyder it doesnt. Either way the plastic ring around the ignition should have a slot for a bulb. Hope that helps.
Yeah it does. Mine lights up but my problem is figuring how to get apart so I can replace the light. Cause it looks like I'll have to take a lot off the steering column but I didn't look long.
