need part #'s: HELP! 2g turbo bell housing bolts
Jafro
309
41
Jul 15, 2003
Richmond, Virginia
So I've managed to kick 2 of my bell housing bolts out and can't fully disengage the clutch. I did a lot of searching on this topic with advanced searches, etc... and I can't find any information that would let me call Mitsubishi and order them. I know someone here has to have done this before, and I hope you see my request because I'm stuck.
The front lower trans bolt, and the rear lower starter bolt peaced out on me. I don't have specs, nor a part number. I have CAPS, but it's NOT in there. Neither are clutch pressure plate bolts surprisingly... I can find transfer case bolts all day long, but not the bell housing bolts.
I need to know what gives on a 2g with the "small bolt"... does it actually have one or is that just a 1g thing. Because if that's the case, I don't have that bolt either. I'd like to order a whole new set of these things because I feel like the flexing due to the missing bolts might have compromised the strength of the other 3 which are still bolted on tight.
Jafro
Bah! I 'bout wet myself until I read the 91-94 part! :(
My version of caps is ancient, but I'd die to know where he found that in there...
Thanks for your help, though! Someday someone with a 1g that searched these tags will see this thread and solve all of their problems...
Sorry, I forgot to put the part numbers are the same as a 2g AWD. The only difference is 2g's don't have 20999P, but instead use 20999U (PNC numbers from pictures in link - see link for actual part numbers).
As for where to find it, you need to look for the arrow keys. The M/T CASE section (22-110) has 3 pages of info. The bolt info (including the pressure plate bolts you're looking for) are on the 2nd page.
