need help with start-up
ts90gsx
Sep 16, 2009
phoenix, Arizona
hey theres nothin much to explain everything is connected i checked the relays and fuses just swaped the motor cant get it to start up. theres a weird ticking sound dat comes from the cruise control box and a louder tick coming from the throttle body. anyone have an idea what it can be? all sensors were working fine before the swap. cranks fine but no spark or fuel.
Start by checking to make sure the crank sensor is getting power, then check and see if the coil is getting power as well as the injector resistor box and then if the power is making it down to the injectors itself. Check and double check all connections again and make sure everything is plugged in tight.
How exactly are you checking to make sure there's no fuel or spark?
Have you tried searching though for the most common fuel/spark issues and ruling those out?
What exactly have you tried/checked/done...
thanks guys i found my problem it was just a simple plug that was on a different plug. LOL
