Need help with replacing these bulbs on my halo's
I can't tell you for sure what bulb. But they look the same as mine inside.
Just get the caps off the back, and then press down the metal clip holding the bulb in, move it so it can swing out of the way, then swing it towards the back of the light, pull the bulb out, unplug the wires. Installation is reverse of removal.
Mine use H3 light bulbs for Low Beam and H1 light bulbs for High Beam.
