NEED help with foglights
ciesla
May 20, 2010
Phillipsburg, New Jersey
i have a 2g eclipse. I recently bought foglights and brackets sine the previous owner took both of them out of my car. However, i do not have the bolts to mount the brackets. Does anyone know what type of bolts i need to mount the brackets.
i don't know the answer to your question but i am in the same boat as you are. i have recently got some oem foglights and trying to make sure i have everything...
As you can see from my pictures i have the foglight assemblies and the bezels too.
They gave me one screw for that i haven't had time to look at what that's supposed to go to.
^ mentioned using a bracket... is that shown in my pictures? is that the black piece connected to the assembly?
i have the wiring harness on these foglight assemblies... but does anyone know if an 97-99 eclipse RS has the actual wiring connected? or do i have to fab my own up?
The bolts are 12mm Mitsu Bolts!. I think there are 3 each side. But no you do not have the bracket. The bracket is a plate that bolts directly to the front of the frame. And then the screws you showed, screws the fog lights to the brackets and then there is two long screws with springs that bolt the top part on for the adjustments. Give me a minute and I'll go get a picture of the brackets.
I'll sell the brackets for 15 shipped.
