Need help with build
hurricanes71
149
Nov 9, 2011
clarksville, Tennessee
I got 2200 to spend right now and all I know about car that I just bought is that it has built head with bigger cams, 16g evo3 turbo. Just looking on where I should start my build, I wanna get to about 350hp thats about it. Any advice on where I should start would be greatly appericated as I am new
This list will get you 350whp.You may need a little more money tho.If you have a 1g then get 2g o2 housing and 2g exhaust manifold.
maintanance
dsmlink/ecmlink
evo3 16g
3 inch exhaust
750cc-1000cc injectors
255 fuelpump
272 cams
Also if your 5 speed you will want a aftermarket clutch and flywheel.
Ok so your fwd I want you to keep in mind wheel spin with those fast little guys, so be careful.The evo3 16g are good price and good turbo but around anything else it gets more exspensive for a bigger laggier turbo and what you would want for fwd so you won't get as much wheel spin.First I would get exhaust find a good 2.5 inch downpipe and a 3 inch exhaust.Don't forget to update your profile with your car mod list that you already have.
Ok and I actually might buy a transmission from guy on here which has a lsd in it so I dont slip as much. But after exhaust should I get a intercooler setup?
ok thanks for the info, any ideas on what brands on the exhaust,bov,intercooler,
Ok so I am going to buy this trasmission off guy on here has 27k miles on it with lsd, next I was going to buy a stage 2 clutch and flywheel and then drop in car. After that I was going to get a fmic and put that on since I dont have one atm. An after that I was going for a apexi n1 3" inch full exhaust system. An with the intercooler setup get a bov (not sure what brand) any ideas on what kind of bov I should get?? How does that sound for a start at building my new car??? Any inputs on what I should change or add would be greatly appericated thanks
