Need help S-AFC Neo wires ripped out
eclipse_gst_99
Feb 7, 2005
phoenix, Arizona
I need help, my car got vandalized and the wires from my safc neo were ripped off from the safc itself. I would like to see if I can solder the wired before spending the money on a new safc. Does anyone now the order of the wires inside the safc, i need this info so i can attempt to solder the wired and see if I can fix it. Thanks, I need to get my car up and running asap.
sorry i don't have a NEO to open up for you, but i assume you have already opened yours up and looked to see if there are any traces of old wire still left on the board... sometimes manufactures put single letter color codes on the board for the assemblers.
Wow, that's going to be hard to find unless you can get someone to open theirs up and take a picture. The SAFC-II actually had a plug in harness inside the housing. Are you sure the Neo doesn't have something similar and perhaps the wiring is still intact at the harness inside the housing? Or did they physically get pulled out of the circuit board or something?
You can always swap back in the 450's and reconnect the MAS wire until you can get things fixed.
There is a plug-in harness inside the NEO but thats were the cables were ripped out completely. there is'nt a trace of any of the wire on the harness. I've checked the NEO board an it doesn't have any color code to determine which cable goes were.
