need help quickly... where is the CAS?
JiveMasterT
1,848
9
Jan 3, 2004
Chest of Westerson, New York
im washing my engine bay right now and i have work in about an hour, and i need to know where the crank angle sensor is if i am looking at the engine bay so i can not spray it with the hose. thanks.
L2RTSiAWD said:
Circle attached to the side of the valve cover.
Well, wouldnt that be the cam angle sensor?
THe CAS (crank) is in right next to the crank gear, so just as long as your timing cover is on, you shouldnt have a problem.... unless you got some nasty cracks and crap in it.
:thumb:
Cover it, your air filter and the MAF and your battery then you should be fine.
